P0440 on 2000 S70 GLT
- mnorris23
- Year and Model: 2000 S70 2.4l GLT
Hey everyone! I wanted to get some advice from the forum on my code that refuses to go away. I have a p0440 code that after replacing my gas cap, purge valve (Which is what the code refers to, the "canister purge valve"), the j hose.I also checked all the lines going from the gas tank to the purge valve all seem to be good. Anyone have any more ideas? I replaced the purge valve around 6 months ago. Unless there is another purge valve I'm missing or its referring to the charcoal canister I'm out of ideas. Thanks y'all, always helping me out!
Car I own: 2000 Volvo S70 GLT 130k Stock with OEM replaced parts.
- Been thanked: 4063 times
You have to get a smoker out to find the leak - the J tube on the canister is a typical leak spot, but its really hard to inspect these without smoke.
- mnorris23
Thanks for the reply! I already replaced the j hose as I mentioned but I'm looking for other areas that typically leak.abscate wrote:You have to get a smoker out to find the leak - the J tube on the canister is a typical leak spot, but its really hard to inspect these without smoke.
- 1917 Views
Last post by benpineapple
- 2254 Views
Last post by VTs70T5M
- 23 Replies
- 4672 Views
- 4882 Views
Last post by timetobakethedonuts
- 2411 Views
Last post by jmorman
