'96 Platinum Wagon: broken timing belt. 7:18am Topic is solved
This topic is in the MVS Volvo Repair Database » Failed Water Pump Causes Timing Belt Failure
splats
Year and Model: 1996 850 Turbo Wagon
Post by splats »
Driving to work this morning, my timing belt broke. There are a couple of things which make it more complicated than a 'simple' broken timing belt:
- The belt only had about 45k miles on it
- I had a 'low oil event' a couple of weeks ago. No oil light, but I had a fair amount of lifter noise which went away after an oil change.
- Was that other noise I heard a spun bearing? (is that possible on these cars? Did the cam sieze and break the belt?)
- Most puzzling of all, I have oil in my coolant that wasn't there 2 weeks ago. (No coolant in the oil, though).
At any rate, I love this car - I finally got all the coolant leaks, vacuum leaks, and sensors fixed. No CEL for 3 months. Everything was working, so this really blows.
I'm going to pull the head and evaluate the damage.
Are there any non-intuitive things about pulling the head on this car? Like: is it easier to pull the exhaust manifold with the head, or leave it with the car? (I've only done this sort of thing with rear wheel drive cars before (non-turbo, too)).
(I've got a garage and another set of wheels...)
==== Cause: Executive Summary ====
The cause of the broken timing belt was a poor, after market water pump. The water pump's bushing disintegrated, allowing the impeller to gouge into the water pump housing until it seized - which, in turn, chewed 8 teeth off of the timing belt - resulting in bent valves.
The oil in the coolant is (most likely) the grease packing from the water pump bushing.
The noise of a spun bearing, was the water pump giving up the ghost.
The 'low oil event' is not a contributing factor.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It had 45k miles on it,but how old it was?Also,what was the brand of timing belt?
Is the car auto or manual?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
splats
Post by splats »
Misha, the belt came with the car (in a box), I don't know how old it is - but it was installed Aug. of 2013. The brand is Continental, and the car is an automatic.
Thanks.
Has thanked: 2197 times
Been thanked: 1850 times
When you take it apart, it would be worth checking the tensioner. I think your car will have the hydraulic tensioner and not the manual one. Was it replaced when the belt was replaced? IT is possible the tensioner failed and took the belt out.
Like you said, the 'low oil' event could be a contributory event and perhaps the engine seized. Does the crank move at all (it may not is a valve has been bent which is likely).
misha
Post by misha »
splats wrote:Misha, the belt came with the car (in a box), I don't know how old it is - but it was installed Aug. of 2013. The brand is Continental, and the car is an automatic.
Ok,the belt brand is ok...what about oil in the coolant?Since the car is auto it could be that radiator failed and let transmission oil in it.
If it's engine oil in coolant....that would be a headgasket.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
splats
Post by splats »
Thanks folks.
- The belt didn't snap, but instead it lost a few teeth.
- The water pump is seized.
When I bought the car, it seemed good to change the timing belt (since it had one that came with the car). It also had some coolant leaks. So I changed out the timing belt, water pump, radiator, heater core, and other stuff as well.
Since then (45k miles ago), I've had to re-replace the intake manifold gasket (dried and cracked - looked a thousand years old), radiator (started leaking past the plastic end caps), and now the water pump has siezed.
I'm learning that after market parts aren't what they use to be...
(...continuing with the head removal. Still puzzled by the oil in the coolant. Coincidence, maybe.)
misha
Post by misha »
Only 45k on water pump and it seized?
What brand was it?
How many teeth?If it is up to 3 teeth,valves would be ok.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
One of mine has oil in the coolant. The cause turned out to be the oil cooler in the radiator ruptured. I only mention it because you had a low oil event first. Did you ever determine where the oil went? Pull the oil lines from the radiator, plug one water hose and pressurize the other, you may see pressure escaping out the oil cooler ports. In my case the trans cooler was fine, by the way.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
splats
Post by splats »
greg850r, The low oil event I *think* was due to the fact that the dipstick handle was broken off before the last oil change I got. I told the folks at the oil change place to use needle nose pliers to get to it. But when I got a new dipstick, I realized that it can get stuffed further down the tube if the handle is broken off. So I suspect the oil change people got a false reading. Just a theory. Although I do have a little oil between the turbo and intercooler - (turbo needs rebuilt).
And the radiator is just a few months old - the one I got in 2013 was failing. But, I suppose it's possible that this one has already failed.
splats
Post by splats »
Misha, there are 8 teeth missing. I don't recall the brand of water pump. I ordered a bunch of parts from a few different places when I got the car, but I have that info somewhere, it'll just take me a while to dig it up.
Thanks again.
