Where does this oil line go? (Found!)
adkvolvonoob
Year and Model: 1999 v70
Post by adkvolvonoob »
Hi!
Putting my 1999 V70 Turbo AWD back together after a valve job, and I can't figure out where this wants to live! It's just around the back corner from the CPS, above the turbo (inlet seen in pic)
Thanks!
Jeff
oil line to head someplace?
Has thanked: 1610 times
Been thanked: 4067 times
Coolant banjo fitting onto the turbo case. You will need the nut
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Looks like the coolant pipe that connects on the side of the head.
rspi wrote:Looks like the coolant pipe that connects on the side of the head.
You are right Robert, that's head side. I don't think I have that bracket on mine but it's been a while since I've been back there
adkvolvonoob
Yeah, that's what I'm thinking (exhaust-side of head), but I can't figure out where. It looks like it wants to lay in a certain area, and that bracket throws me farther off into the woods.
adkvolvonoob
abscate wrote:Coolant banjo fitting onto the turbo case. You will need the nut
I have 3 lines already connected, and I don't recall seeing a place for a 4th.
rspi
Post by rspi »
I believe it bends under the bracket/Cam sensor. I don't have one nearby or I'd do a pic. :(
There might be a picture in my CBV thread
The turbo banjo connector takes coolant off the back of the engine, so look back there.
adkvolvonoob
Found it! Thanks everyone!
It is indeed below and left of the CPS. The hose is designed to double-back more than it is to bend around the corner.
