Hi, I'm looking for some help on my friends 02 Volvo v70xc we've been working on. We had a severely stuck cv axle on the drivers side. From all my searching it seems to be a common issue with these cars. After searching forever I took some "apparent" bad advice from another thread. I removed the passenger axle and attempted to force it out from that side. After 2 taps on my punch I got transmission fluid leaking out the transfer case.
I've since been able to get the broken axle stub out of the drivers side using a puller with a 1/2" bolt welded to the stub.
Now I'm trying to address the leak. I dropped the transfer case from the transmission but I'm still unable to get to that seal. It seems it would be in the transmission between where the 2 axles meet. Is this a serviceable part without dropping the transmission and opening the case? This is my first time working on a Volvo. I'm a pretty experienced DIY mechanic otherwise.
Obviously in hindsight I wish I wouldn't have attempted this method but now I just need to get it fixed. Any help is appreciated.
It's an automatic transmission btw.
Stuck axle/transmission issues
- 616 Views
Last post by Blacklab467
- 1503 Views
Last post by TechnicALFA
- 1030 Views
Last post by dsharp
- 42 Replies
- 7974 Views
Last post by bmdubya1198
- 22 Replies
- 4392 Views
