I just started having problems with my XC70. I was in traffic in Tucson and I noticed that my car was overheating. I pulled out of traffic and stopped the car. The coolant level was low and I waited for the engine to cool down before opening up the reservoir to top it off. It was very low and will have to figure out where it went to later. Now I need to figure out why my fan is not coming on. From everything I have read so far, My year does not have a fan relay. It is a module control mounted on the fan. With just a two wire connector for power and one purple wire for control from the ECM. I have tried turning on the A/C to get the fan to come on, but the fan does not come on.
How can I test to see if it is a power part of the fan or the control(ECM) part that is not working as designed? I just don't want to go out and buy a new fan if it is an ECM issue. The system is not throwing codes. When I plug in my reader, it will read the engine temperature, but if it times out during troubleshooting when the reader comes back on the engine temperature does not read. I can not trust my dash gauge because they have been intermittent for some time now and that too is an issue that I am working on.
Any test procedures or ideas would be greatly appreciated.
2002 XC-70 overheat
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
that module goes bad. I replaced my module with one bought used, just cut and reweld the wire . the coolant temp sensor (along with the thermostat) also can go bad
Oragex, What is that module called. My daughters s60 is sporatically overheating while sitting at the gas station waiting to get gas.
Thanks,
Shannon
Thanks,
Shannon
'96 855 NA 269,000
'94 854 Turbo 162,000 rebuilding the head after a burned valve
'95 854 Turbo parts car
'03 V70 XC 142,000
'04 V70 NA 230,000
'04 S60 NA 152,000 oldest daughter's car
2005 Mazda 5, 5sd 163,000
2001 Excursion 7.3 power stroke 135,000
'03 V70 XC 142,000
'04 V70 NA 230,000
- 908 Views
Last post by 93Regina
- 1900 Views
Last post by ThinAir
- 27 Replies
- 3471 Views
Last post by misha
- 12 Replies
- 2540 Views
- 3286 Views
Last post by osolanog850
