Limp Home Mode
agloy63
Year and Model: 2002 S60
Post by agloy63 »
I posted this in the wrong forum earlier. Hopefully someone can help.
I suddenly have an issue where at random times my engine will go into limp home mode. This can be cleared by shutting down the engine for a couple of minutes, or by using my OBD WiFi connection and an app on my iPad to clear the code as I'm still driving.
The codes I'm seeing are:
P0068 MAP/MAF - Throttle Position Correlation
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
2002 S60 2.4T AWD
Any advise would certainly be appreciated.
Kurica
Year and Model: 2002 s60
Post by Kurica »
Try to connect to VIDA and get the right codes, it can even tell you what to do, other then that is hard to be accurate.
agloy63
Post by agloy63 »
Finally was able to get a unit. Here are the codes.
BCM-0040
BCM-0057
CCM-0003
CCM-0021
DDM-0049
PSM-0038
CEM-6A04
DDM-0024
DDM-002B
BCM-0065
CEM-1A54
CEM-1A55
CEM-1A56
CEM-1A5B
CEM-1C02
CEM-1E04
CEM-6A01
CEM-6A03
CEM-6F71
DDM-0022
SRS-0005
Kurica
Post by Kurica »
ok, quite a few. Did you dig about any? I've been out for a bit only now i saw your reply.
Has thanked: 1609 times
Been thanked: 4065 times
Clear all those codes and see what comes back.
Not a single ECM. Code??
