Hi there,
I noticed that my ignition key does not fit the glovebox. The key for that looks like a more regular key.
So the question is, is there any way to get a new key that fits the glove box lock? If so, what is the cheapest way?
I dont put anything too valuable in there but might want to lock it anyway.
Thanks.
Key for Glovebox
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- Been thanked: 4069 times
Probably remove the lid and bring a blank and lid to locksmith. It might not be cheap
- misha
- Has thanked: 155 times
- Been thanked: 432 times
My glovebox lock use the same key as ignition lock.
Probably the glovebox was replaced sometimes in the past because they tend to lock themselves.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
^^^ either the glovebox lock was replaced in the past - or you have a "valet" key and not a "master" key.
Volvos at that time shipped with two "master" keys - which work all the locks, and one "valet" key, which is a bit shorter and only works the door locks and ignition locks. The thought is that if you valet parked your car, you could lock your valuables in the glove box, give the valet person the valet key, and they could do what they needed to do with your car but not be able to access the contents of your glove box.
You would need to purchase a new master key for your vehicle if you want to be able to lock the glovebox. The stealer should be able to get that for you.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
- Has thanked: 311 times
- Been thanked: 817 times
What 101 said!
My valet key on my 1999 is a lighter gray than the master key, FWIW
- misha
I don't know...i don't have that "vallet key",i have one chipped key and it operates all the locks on the car,including glovebox.All locks are genuine and neither one was ever replaced.
Spare key also operates all the locks.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
The master keys will work everything - even the lock on the trunk cover on the wagon. The one valet key will not open the glovebox or trunk cover on the wagon.
My 1999 came with two master keys with FOBS and one valet key
On my P80 cars, the only way to tell the valet key is by comparing with the master - the valet has a shorter groove.
- MrAl
Hi again,
Thanks for the replies, very interesting.
I think mine must have had the glove box door replaced because the key hole is much smaller than the door lock holes and the key thickness would never fit in there regardless how long it was, short or very long. It fact it looks more like a 'regular' key not the 3d type which my vehicle currently has. It looks like it takes a regular 2d key like that which would fit in a padlock or something. Strange, but then again every time i turn around i find something else strange on this car...maybe tomorrow i'll find a button that makes it fly
- 1253 Views
- 11 Replies
- 2694 Views
Last post by mecheng
- 2244 Views
Last post by matthew1
- 488 Views
Last post by vtl
- 12 Replies
- 1335 Views
Last post by SirBrickWagon
