S70 loss of power
hendrixscottie
- Year and Model: 2000 S70
I have a 2000 Volvo S70 non turbo , driving through town yesterday it loss power and as I coasted to the side of the road cut off, the ETS light came on at this time. I checked the codes and got several that pointed towards the ETS but also the crankshaft sensor. I was showing signs of the ETS going out before like rpm unsteady when stopping but I was wandering if the ETS going out could cause the crankshaft codes to come on. The car will not start at all right now. Would the car start up if you sprayed starting fluid in the intake?
Give it a try with ether, that will definitively tell you if you have a spark/timing problem or a fuel problem
Clear all the codes, after you have written them down. These cars tend to generate a ton of codes when things go bad, many times half of them are spurious and don't point to trouble,
When I popped a turbo hose the other week, I got a turbo code as well as a ETS light - neither of which required attention.
hendrixscottie
With throttle assembly removed I sprayed starting fluid in the intake nothing happened now I'm worried
hendrixscottie
I now have noticed that the drive belt has shredded only about half of it is left on the pulleys. Timing belt is still on and looks ok though.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
When you say it won't start - do you mean it won't crank, or it won't fire and catch?
Do you smell fuel coming out the exhaust?
hendrixscottie
It turns over fine just won't crank and run. One of the codes was from the crankshaft sensor so I am going to replace it and go from there the car has over 300000 miles on it so it is due one anyhow. It did pop twice like it wanted to try to crank.
I would deal with that timing belt before it fires...its a $2000 bill if it breaks...
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
If the wiring insulation on the crank sensor has turned to goo and fallen off, causing the wires to short, it can cause this code.hendrixscottie wrote:It turns over fine just won't crank and run. One of the codes was from the crankshaft sensor so I am going to replace it and go from there the car has over 300000 miles on it so it is due one anyhow. It did pop twice like it wanted to try to crank.
M1 10W-30 HM
M1 10W-30 HM
Wait - is it the serpentine belt that is shredded and the timing belt is fine?
Thats less serious. The AC might be frozen up which can stop the engine but usually you will hear it firing.
It sounds like you have a ignition problem, perhaps check 12 VDC on the coils' supply
hendrixscottie
Timing belt is Ok the serpentine is shredded. Found out when looking real close the motor mount has broke and the front pulley cut into it that's what tore up the belt. Hopeing that the crank sensor gets it running again and I'll fix the mount and install a new belt
- 886 Views
Last post by 93Regina
- 38 Replies
- 12204 Views
Last post by mrbrian200
- 41 Replies
- 5765 Views
Last post by erikv11
- 1897 Views
Last post by ollebompa
- 2440 Views
