Like the font used on the dashboard and on the 12v power socket caps, etc.
Is this a standard font that can be purchased or downloaded or is this a proprietary font only they use? Thanks.
What is the Volvo font used in the V and S series cars?
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I have not found a font name. I believe it's a custom graphic.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Have you tried font search engines like
https://www.myfonts.com/WhatTheFont/
As a professional designer I tell you people are lazy, there is a good chance it is a standard font, maybe slighty stretched or sthg.
But then, as Robert suggests, it might be a custom font as they usually do with most car logos and lettering on the tailgate / trunk.
If you can post a pic of your Dashboard I can take a look.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If you're asking about numbers on instrument cluster and switch names,logos and badges....it's proprietary font only they use and it's recognizable Volvo font.SonicAdventure wrote:Like the font used on the dashboard and on the 12v power socket caps, etc.
Renaults have similiar numbers and font style but again,only unique to Renaults.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
Now I was curious, according to a web source the instrument cluster font is Handel Gothic.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
ip cluster iirc must be legible by the common driver and cannot be hindered by a company's proprietariness. YMM and other display items that don't require a need to abided by a DOT standard is up for bedazzling.
ugh smh 850 Turbo fridge
- 1311 Views
Last post by MadeInJapan
- 4976 Views
- 11 Replies
- 3764 Views
Last post by equiprx
- 4521 Views
Last post by June
- 16 Replies
- 3329 Views
Last post by smacknab
