high beam lights wont dim
kathy hambly
- Year and Model: 1998 s70 t5 sf
i have a 1998 s70 sedan the hi beam lights wont dim.We changed signal/dimmer switch no change, all bulbs good has anyone had this issue
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Probably a short inside the light assembly. Open the cap on the back of the light and check the wires in there.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
So the high beams won't turn off? They're controlled by a relay so if they're "stuck on", I would think the relay is faulty.
M1 10W-30 HM
M1 10W-30 HM
kathy hambly
i disconnected front head lights high beam indicater still on in dash . high beams com on with ignition switch. opened head lamp double type relay rear coil is activated isolated it, high beams off. is there a step relay or something that activates high beam in main relay
