Boost pressure too low
Matt88ch
- Year and Model: 2000 s70 glt se
I have a 2000 s70 glt se lpt, i have the Bluetooth obd adapter and torque pro app. When I have the vacuum/boost gauge the highest boost I've reached is 3.6 I read stock psi for the stock lpt should be 6-7 psi...I'm thinking vacuum lines must be old and brittle or maybe have a hole? Any ideas or recommendations are appreciated. Thanks guys.
- Has thanked: 311 times
- Been thanked: 817 times
The torque app is just calculating the boost, it's not actually reading it. The word on the street is those calculated numbers are not very reliable. But if none of the narrow rubber vacuum lines have been replaced in 17 years, I would swap out every one of them. It's cheap and not too much hassle, pick away at it over one or two weekends. The boost will probably improve if you do.
Another thing to watch for is a hole in the CBV diaphragm, again very common for a 17 year old rubber part that constantly flexes back and forth. But you would usually notice that while driving - I would start with replacing the lines.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You really need to install a boost gauge to see what the real pressure is.
Matt88ch
Yeah I'm planning on getting one this weekend....I have no check engine light so I know it's not a big problem, I was just curious on what the psi was and when I saw 3.6 it got me thinking about the vacuum lines...Although I did replace some but not all. I'll try to do the rest this weekend and post up my psi after I get a real boost gauge. I always thought that the OBD2 port w the adapter would give me a accurate reading, but I guess nothing beats a good old boost gauge tapped into the vacuum lines. Thanks guys
Your 2000 has an actual manifold pressure sensor that ypu can access by obd, I don't know if your software supports it though.
The turbo control valves (TCV) also get tired with age..it's a fairly fast duty cycle solenoid (100Hz?) so it is harder to diagnose without fancy stuff. I started seeing BMWs in my rear view after I replaced mine at 140k
Matt88ch
Is to possible to test the tcv...I have a spare one from my parts car maybe I'll swap it and see if it makes a difference, thanks budabscate wrote:Your 2000 has an actual manifold pressure sensor that ypu can access by obd, I don't know if your software supports it though.
You need some pretty good equipment to test a TCV - usually you replace on age (10 years/100k miles)
The coil resistance test doesn't tell you much, spec is 29.7 Ohms with no error bars given.
- 904 Views
Last post by Biotik
- 2494 Views
Last post by Volvo Kush
- 8893 Views
Last post by rhubarb
- 21 Replies
- 1031 Views
Last post by jonesg
- 2118 Views
Last post by RickHaleParker
