Hi.
My 1994 940 wagon (non turbo) was having problems changing from 2nd to 3rd. A friend of mine rebuilds it ($600) and it's working pretty good 1, 2 and 3.....but now the 4th gear (overdrive) it is not engaging. I sent it back to the mechanic for a full review. He said it's nothing inside the transmission, maybe an electrical issue.
I had read a lot of threads about this issue and applied all of the solutions found and still not working.
-I replaced the overdrive solenoid with a new one ($100) and doesn't work; the activation click test was performed. We test with other used solenoid.
-A new Overdrive Relay ($40) doesn't work either.
-A by pass to the new solenoid was made to have a permanent solution and doesn't work.
-The kickback cable was inspected and adjusted in various ways and nothing.
Is there anything else that could cause this problem?
Thank you in advance.
Fourth gear not engaging 1994 940 Wagon
- 1101 Views
Last post by wizechatmgr
- 13 Replies
- 4729 Views
- 11 Replies
- 2704 Views
Last post by bmdubya1198
- 22 Replies
- 9366 Views
Last post by 5ft24
- 922 Views
Last post by Jat007
