I thought I made a post about this already but I can't find it so I am making a new one.
The windshield washer on my 2002 V70 is driving me bonkers. Ever since I had the car the passenger side washer hasn't worked properly. Most of the time I would get little or no stream out of it.
This weekend I decided to fix it.
I pulled all the lines, check valves and pump from my 2001 V70 which works nicely. I narrowed it down to the one way valves and after swapping those out it started working or so I thought. It worked for the last 3 days but got progressively worse and I am now back to where I started. I get small stream from the passenger side which barely reaches the windshield. Driver side works ok but doesn't feel like it sprays as strong as the 2001.
Is there a permanent fix for this or is this a Volvo thing that I gotta live with? Has anyone swapped to a more powerful pump from another car or perhaps got rid of the one way valves?
Windshield washer is driving me nuts
Canadian Moose
- Year and Model: 2002 V70
- Been thanked: 4064 times
They work great. You've got junk and dirt in your system which will plug it up. I guess you Wil have to tear out thecreservoir and get it clean...ugly job.
Canadian Moose
The reservoir looks clean. Whenever I take everything apart and check for blockages there are none.
Edit: Just saw a related thread pop up. I wonder if this valve is what's causing my issue. I didn't touch anything related to the headlights.
viewtopic.php?f=1&t=47698
Canadian Moose
I ended up gutting both one way valves and that 3 way valve. Takes a second longer for the fluid to start spraying but don't have to worry about them braking any more.
- 677 Views
Last post by Ozark Lee
- 18 Replies
- 6916 Views
Last post by sleddriver
- 1425 Views
Last post by TWC
- 366 Views
- 15 Replies
- 8628 Views
Last post by volvolugnut
