IPD sale Volvo Parts
99 T5 - what's this thing Topic is solved
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 5 times
United States of America
Post by j-dawg » Wed Feb 15, 2017 8:51 pm
I've got the intake manifold off and noticed a wire and connector loose from their sensor. The sensor itself is pretty small, and it looks like the connector for the sole wire broke off long ago, apparently with no ill effects.
Anyone know what this is?
1999 V70 T5 5-SPD | ~270k mi | burns more oil than gasoline
j-dawg
Re: 99 T5 - what's this thing  Topic is solved
Post by j-dawg » Wed Feb 15, 2017 8:55 pm
Welp, looks like the oil pressure sensor. Curious that I haven't seen any oil pressure warning lights, then.
Does anyone know if I can change this without dumping the oil? I was hoping to run on this oil for a few dozen miles after I get the head back together and then change it, but I probably need the intake manifold off to change the sensor, and I'm not looking forward to doing that again.
Year and Model: 850, S/V70, 06 S60R
Has thanked: 23 times
Been thanked: 52 times
Post by erikv11 » Wed Feb 15, 2017 9:31 pm
Yes you can plug/unplug oil pressure sensor without spilling any oil. I have plugged/unplugged it without removing anything (e.g. intake manifold) on my NA, but never tried it on a turbo model. Not sure how tough the access is.
'95 854 T5-R || m4.4 || 185k
'96 855 NA || 145k
'98 V70 GLT || T5 tune-injectors-turbo || 275k
'06 S60 R || 145k
gone: '96 NA 850 210k, '98 NA V70 182k, '98 NA S70 174k
ecbsykes
Year and Model: 2000 V70XC
Has thanked: 5 times
Been thanked: 9 times
Post by ecbsykes » Wed Feb 15, 2017 9:42 pm
Is your oil pressure warning light burned out?
Ed Sykes
2000 V70XC - Emerald Green - 260,000 miles
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 43 times
Been thanked: 173 times
Trinidad & Tobago
Post by abscate » Thu Feb 16, 2017 4:21 am
Yikes. That can end badly. Bulb must be out
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
rspi
Has thanked: 9 times
Been thanked: 15 times
Post by rspi » Thu Feb 16, 2017 8:45 am
Strange thing with these cars, when you unplug that sensor, the light does NOT come on. Hook it back up and the light works as normal.
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
Post by erikv11 » Thu Feb 16, 2017 9:30 am
Robert I actually had the light come on on my 96 NA, because the sensor somehow came unplugged. Then I plugged it back in and the light went off. That's the main reason I know about plugging/unplugging it. So maybe that's not always true.
'96 855 NA || 145k
'06 S60 R || 145k
j-dawg
Post by j-dawg » Thu Feb 16, 2017 10:18 am
I turned the key to see if the oil light would come on. I didn't see it in my brief scan of the instrument panel, but then I heard gasoline spraying out of the open fuel line and quickly switched it off. I am an idiot.
Further evidence of idiocy: I was using a wooden dowel to find BDC so I could stuff a rope in Cylinder 4 to swap the valve stem seals. I heard a "snap" noise and withdrew the dowel to find it had snapped - but thankfully not broken - within the cylinder. Breathing a sigh of relief, I immediately flipped the dowel over and stuck the other end in the cylinder, which did snap off inside. I had to spend the next half hour feverishly extracting the (fortunately small) sliver of wood using compressed air and a zip tie with a blob of grease on it. I was nearly convinced that I'd have to pull the head.
Not sure why this happened twice on cylinder 4 when cylinders 1, 2, and 3 showed no sign of it, but after getting burned twice I learned my lesson. I could probably break a car just by sitting in it.
Trinidad & Tobago
Post by abscate » Thu Feb 16, 2017 10:55 am
You still pale compared to the idiot here who installed his intercooler upside down
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
amblerman
Year and Model: 1999 s70
Post by amblerman » Thu Feb 16, 2017 11:58 am
If you look at the 4th picture, it also looks like you're missing a bolt for your starter bracket.
Strange thing is, I too am missing that and will be picking up a replacement bolt from dealer later today.
-A
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: fortim, juggles, LOB, rsp and 59 guests
