My son's car, 2002 Volvo V70XC, 319700 miles. Upon starting the other day the engine ate a mouse that was nesting in the Timing Belt. He didn't know it at the time but the engine immediately started making a loud rapping sound. He stopped it and called me. When I took the covers off I noticed the mouse body parts squished in the belt and pulleys.
My question is, could the mouse body cause the belt to jump a tooth on the gears? If so would it cause the valves to make an extremely loud rapping noise? I can borrow the tool for aligning the cams and actually have the parts already purchased.
2002 XC70 - mouse body parts in the belt and pulleys
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Poor little mouse! After cleaning out the mess, which shouldn't be a lot, you could always check the timing marks.
I assume the car hasn't run in a while, like a few weeks. The oil can completely drain out of the lifters at that point. As soon as oil pressure comes up to 'normal', the lifters will get nice and quiet again. Before you start it again, charge the battery. You may experience "lawn mower syndrome" as the gasoline washed the rings during cold start and compression may be low.
I seriously doubt that the timing will be off.
Klaus
mlanctot
- Year and Model: 1999 S80T6
I'm going to check timing marks now. Its like 50 degrees here in Connecticut. I've had Volvo's for a long time. Never heard an engine this loud! This car was originally my Wife's. One owner car.
Klausc
NO! Do not remove the pulley. The crank mark is extremely difficult to see. You need a flashlight and view it from above.
You cannot remove the pulley until you know where the crank mark is. Try rotating the engine 180 degrees and look again.
Klaus
mlanctot
OK, before I read this, I had my son give me a hand. He turned the crank and I watched for the marks.
The belt jumped. I have the lower marks set and the upper cam marks are about five teeth past.
Should I remove the belt and rotate the cams BACK to the Marks? And set from there?
Klausc
5 teeth is a long way. I would have never expected a mouse to have enough body mass to do that kind of damage.
Go ahead and align the marks. Watch out for the VVT, as it will want to turn backwards just a bit.
You may be looking at a valve job...
Klaus
mlanctot
Up date: Like I said , I have all the parts to upgrade this engine, parts from FCP.
Every thing has been removed. I'll tackle this tomorrow. The upper cam have been aligned. Tensioner installed. Idler installed.
Thanks for the assistance!!
mlanctot
OK, want to finish today. New water pump, idler, belt adjuster completed.
Trying to get the timing belt on. Any tricks for this. Adjuster slackened all the way. Hard to see how to get belt over cam pulley. Not long enough.
- 27 Replies
- 3591 Views
Last post by V50M66
- 10728 Views
Last post by vtl
- 594 Views
Last post by robinslusher
- 1025 Views
Last post by misha
- 1067 Views
Last post by goldbrick960
