01 C70 Knock Sensor Question on orientation with pic Topic is solved
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
I am replacing the PCV system on this C70 and by mistake removed the bolt holding the Knock Sensor. On Robert video he indicates that the position is important. Any ideas how to know correct position for my car. I can copy what Roberts has but the sensor I did not disconnect has different position that his has.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
cuhfs
Post by cuhfs »
Problem solved I need 3:00 and here is the instructions i found for the 2001 C70 in case it helps someone else.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Has thanked: 1610 times
Been thanked: 4068 times
This Image is actually incorrect - see thread below
Here is the visual for those so oriented ..
cuhfs
Post by cuhfs »
Thanks. Actually the front one (cyl 2) is 3:00 and the back (driverside) cyl4 one 6:00. Picture you posted has the opposite. (The KS i did not touch is the one on the back of engine cyl 4 and that remains 6:00. One on the passenger side I removed by mistake & Put it back to 3:00.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Hmmm..wonder if it changed in 1999 ?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
The angle for the knock sensor on the left (cylinder 2) was 3:00 for 93-98 P80 cars, if you think about it it almost has to be because otherwise the oil trap will get in the way of the connector. So that one didn't change.
For the 93-98 P80 cars, the angle for the knock sensor on the right is 5:00, so it seems that one changed at some point. Strange ...
Im vaguely remembering having this thought process when I did my PCV and knock sensors on my 1999, and sure enough my picture shows the ALLdata picture above is wrong.
harrelldodd
Year and Model: 1999 s70
Post by harrelldodd »
im confused i have a 1999 s70 non turbo and everything ive seen has 2 sensors into one plug but when i got into mine i only find 1 sensor into one plug and autozone says there is two sensors. but i only see one .my question is where is the 2nd one located?
any help would be great thankyou ahead of time
