Scanners
Jaguar xjs
Year and Model: 1996 850 turbo
Post by Jaguar xjs »
Ok gent, I've read 100's of threads on scanners.
If I buy a MaxiDiag Elite 802 for about $200 am I buying what I need to diagnose and turn off the CE lights on a 96 850? I'm a tool junkie so the price dose not scare me off.
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
If all you need to do is pull P codes and clear the CEL then you can do that with the cheap Harbor Freight scanner but it has no real time monitoring like the better scanners have.
I don't believe that model will get you the other goodies like SRS and ABS though.
sacricide
Year and Model: 1997 Volvo 850R
Post by sacricide »
That scan tool won't be all that useful. Mainly because the older Volvo obd port doesnt output codes from all the modules. An inexpensive DIY tool using a LED bulb and a wire pins is easier to extract codes than that tool. (If u aren't familiar check the forum) otherwise that tool is overkill
I actually own that exactly scan tool (great for newer cars and Volvo's) as well as a launch tablet with bidirectional capabilities
Has thanked: 1609 times
Been thanked: 4064 times
The AUTEL 500 series on up will get you SRS and ABS reset function.
For a moment, that bad 1970s movie came to mind...
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
I keep this in the armrest https://www.amazon.com/Autel-MaxiScan-M ... =autel+obd to reset that P0455 or P0442 that pops up every once in a while.
And I have a Matco (MD1400) branded version of this Actron scanner https://www.amazon.com/Actron-CP9580A-E ... ctron+obd2 that I purchased on ebay for $60, it does diagnostic stuff.
Though, none of those reset the service or ABS lights... For the Service light, I have a tool like this that I purchased off of eBay.
http://www.ebay.com/itm/10-in-1-Service ... 50&vxp=mtr.
I think the three tools came out to about $100 altogether.
Retired:
2015 Volvo S60, T5, 85K
