'96 850 T Trailer-hitching
I have a code P0103 (mass or volume air flow, A circuit high) and at speed, I sometimes experience a jerking sensation. It lasts for a second or two then goes away. Anyone have any clue what's going on? It seems to be more prevalent when the ambient temperature is above 70 degrees F. TIA!
Ernie Shack
AZ VSA Chapter President
'66 1800S, '96 850 Platinum Turbo Sedan, '98 S90
- Has thanked: 1613 times
- Been thanked: 4078 times
What is the history on your ignition parts...time and miles?
Coil.
Wires
Plugs
Distributor cap
Rotor
Open up,the distributor and look for oil/moisture
Pull the plugs and evaluate each cylinder. Compression test any cylinder test looks funky
Coil.
Wires
Plugs
Distributor cap
Rotor
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
So what is with this title.
- 16 Replies
- 9590 Views
- 1734 Views
Last post by Rohlfiba
- 2459 Views
Last post by combatkarl
- 1034 Views
Last post by ashitaka695
- 3232 Views
Last post by matthew1
