2001 Volvo aw55-50sn rebuilt but no gears
Hello, this is my first post! I have rebuilt my 2001 Volvo V70 FW Turbo with an aw55-50sn transmission. It's my first tranmission but not my first time working on a car. So i rebuilt it fully (all seals, clutches, valve body, etc.). Put it back in, put oil in, fired it up. I have no leaks, I had a snap on computer attached and so i have no codes, there is no grinding noise and here it comes..... the transmission does nothing. I can hear a small amount of rpm changes when i change gears. The front of the car is off the ground, I haven't put the brakes and wheels back on. I tested the oil ports on the transmission they all seem to have oil flowing through them. I put a gauge on the main lube shaft port and the SLT but didn't get a response at all. But I didn't reve it up too much. I put it in a new torque converter as well and it is attached to the flywheel. So i have no movement at all. Does anyone know what other tests i can do before dropping the transmission and subframe again? Thanksf or your help in advance!!
zanzabar
- Year and Model: '07 V70, '84 245
- Has thanked: 1 time
- Been thanked: 4 times
You sure you put enough transmission fluid in? Maybe the torque converter isn't full enough?
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
- Has thanked: 2854 times
- Been thanked: 1332 times
I just noticed this topic. It's a duplicate, so I'm locking and adding the URL of its mirror.
V70 Transmission Rebuilt No Movement No Gears
- 278 Views
Last post by vtl
- 1729 Views
Last post by BEJinFbk
- 16 Replies
- 14668 Views
Last post by vt9000cse
- 11 Replies
- 4360 Views
Last post by precopster
- 1645 Views
Last post by dadyer
