Intake Manifold, which bolt goes where? Topic is solved
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 464 times
Been thanked: 1371 times
Re: Intake Manifold, which bolt goes where?
Clamp,with the rubber bushing holds the thick brake booster vacuum hose
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
Cook.p.michael
Year and Model: 1996 850 turbo 2.3
Post by Cook.p.michael »
bump
Has thanked: 138 times
Been thanked: 376 times
Post by erikv11 »
first pic: clamps onto the drivers side of the head, holds the vacuum tubing.
second pic: lower drivers side intake manifold bolt, holds the PCV pipe
third pic: the thinnest ones look like MAF screws, the pointy ones look like cowl screws, the blunt ones look like cam cover screws.
fourth pic: this bracket houses the connectors for the cam sensor and crank sensor, also goes on the end of the head like pic 1.
fifth pic: heat shield, over exhaust, firewall side of head
sixth pic: heat shield screws
seventh pic: I see a thermostat housing gasket (two rectangles), then turbo return gasket and/or SAS pipe gasket, some AC o-rings
eighth pic: Fuel line bracket (the smaller one) and I've seen the other piece but drawing a blank.
ninth pic: I think it goes down on the transmission, for the bundle of wires to the PNP, would have to look.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6 :shock: 130k
gone: '96 NA 850 210k, '98 NA V70 182k
Cook.p.michael
Thank you much, i know foreign cars are meant to have extra parts but this is too many :D
