Oil Filler Cap Will Not Twist Off
I'm driving a 2002 S60 non turbo. I went to top off the oil and the filler cap will not twist off. I used 2 hands and all my strength but the cap will not twist off. I understand how the 2 tabs on the cap lock under the valve cover , so a simple half twist counter clockwise should remove it, but it won't budge. For now I'm topping off the oil by using a tiny funnel and pouring it down the dipstick tube. I can't see doing that the next time I do an oil change, it will take all day. I could use a pair of channel locks but the cap is plastic and the metal part might stay on the engine. Anyone else ever had this happen ? I have a 98 V70 and 98 S70 and never experienced this. There has to be a way to get the cap off without destroying it or causing damage to the valve cover. Its not leaking so worst case would be to continue to fill thru the dipstick tube. I'm totally frustrated, any suggestions appreciated.
Get a spare from a junkyard (or see my parts list) and a big pipe or chain wrench and twist that sucker off. Remove any left over parts.Put new one on.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Looks like Mr Hulk is back in town
The cap doesn't 'lock'. Try the channel lock gently, and pry with a bar between the pliers and a metal part on engine top. But first get a new cap before removing the old.
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
I would wrap it with a bunch of wraps of masking tape or duct tape to protect it and use a big channel lock plier to loosen it. It will probably spin right off. Lefty loosy! A strap wrinch is also a good idea if you have one.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Try to unscrew it when engine is warm.Probably just a rubber seal stuck onto filler neck.It happens usually when seal is not lubricated with oil.Just a thin layer like on oil filter gasket and screw it on.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
brick_and_motor
- Year and Model: 1998 V70 GLT;
Channelocks and gentle pressure.
1998 V70 GLT
1998 S70 NA
1988 Chevrolet C1500
1998 S70 NA
Are you positive it isn't already unlocked and isn't just stuck vertically? I'm too proud to tell you how long I wrestled with a VW one , once.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Pipe wrench.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 12 Replies
- 1666 Views
- 1247 Views
Last post by instarx
- 3743 Views
Last post by precopster
- 751 Views
Last post by tryingbe
- 1413 Views
Last post by bmdubya1198
