I have a 1993 240 DL that stalls periodicaly. It always happens when it is at idle speed. Starts right up after it stalls. It just passed smog with good numbers. Plugs look good as does rotor and distributor cap. I had a repairman work on the brakes and it stalled on him so he adjusted the idle upwards. However problem still persists. Sometimes it goes for weeks without stalling then for no apparent reason it stalls. Anyone have any ideas on this.
Thanks,
Chris M.
Stalling 240DL
wojeepster
- Year and Model:
Check small rubber hose that goes from intake (just behind throttle body) to fuel pressure regulator. If this hose is leaking or falls off car will stall when you come up to stop sign.
- 32 Replies
- 8761 Views
Last post by Edger
- 7705 Views
Last post by enriquepr21
- 2979 Views
Last post by Brickhaus66
- 1582 Views
Last post by 93Regina
- 1108 Views
Last post by rgk
