My 1995 Volvo 850GLT has 122,000 miles on it. It's a manual, non-turbo.
It runs well generally speaking. I'm going to put it in the shop at some point soon for some cabin work, leather/headline types of things.
As it turns 125,000 soon, what are the things I should have looked at by my mechanic to help insure my car lasts another 100,000.
I love my car and have no desire to sell it etc. Any and all suggestions appreciated.
What should I invest in to check/repair
- Has thanked: 311 times
- Been thanked: 817 times
The factory front suspension tends to fall apart in the 110k - 150k range. Check out the control arms, tie rod ends, sway bar end links, struts and spring seats.
magna224
- Year and Model: 850 T5's
- Been thanked: 4 times
They both have great ideas. Freshening up the suspension will make you love your car even more unless somehow it's managed to hold up exceedingly well. You can do with a poor ride for a while but you can't do without a timing belt though. I'd say to do the timing belt and water pump first and suspension next. My pump blew at 140k while my other car I don't think ever had a new pump its entire 300k mile life. If you do the timing belt might as well get everything down there taken care of too.
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
Volvo 854 T5 1996
Toyota MR2 1987
I agree, timing pathway parts first!
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Your PCV system is probably still fine at that mileage if you were diligent about oil changes, but it never hurts to check. Do the "glove test" for peace of mind.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Worth inspecting the above along with the dust booths at the steering rack. If any of these are still good, no need to replace them now, these are quite easily replaced later on.erikv11 wrote:The factory front suspension tends to fall apart in the 110k - 150k range. Check out the control arms, tie rod ends, sway bar end links, struts and spring seats.
The most important thing to know is which replacement brands should be used. Read here on forums.
Yours being a non turbo, you need to remove the air box thermostat and set the flap for cold air, similar to this
The PCV must be inspected by now.
Regardless of the condition, I would replace all 4 shock absorbers along with the front spring seats: very important to buy only the brands people recommend here for these parts.
I'd remove the serpentine belt and inspect by hand the alternator, a/c compressor and tensioner pulleys.
Replace the coolant thermostat if original.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Change the transmission fluid. Makes shifting feel smoooother!
Retired:
2015 Volvo S60, T5, 85K
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Not long ago. I checked yesterday, I have 80,000 miles to go on that.tryingbe wrote:When was the timing belt/waterpump last changed?
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
- 801 Views
- 1447 Views
Last post by oragex
- 774 Views
Last post by RickHaleParker
- 1578 Views
Last post by CIK7
- 884 Views
