Hello again,
I'm looking to replace my fuel/evap system piece by piece (96 850 Platinum wagon, 197k) and I'm currently trying to find this part:
I want to say it's a check valve of some sort, between the manifold and the vapor canister purge valve. Can't seem to make out the numbers on my photo, and my eyesight is too poor to see it in person lol. I can't find it on any parts diagram; I see it pictured, but I don't see any number or description. Perhaps I can get a generic one somewhere?
Bob
Name that part!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Between intake manifold and purge valve shouldn't be anything but a hose.
I would say that it's something that shouldn't be there...at least on n/a cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I can't speak for a NA car, but on my 98 GLT I had to replace one of these valves as well. They are easily tested by trying to blow through it from both directions. If the valve is good, it should only pass air in one direction.
For the replacement, Volvo showed only an "assembly" that contained all the hoses for this system and the two check valves all together for something like $90. Um ... nope!
I ordered 1275226 - Volvo EVAP Check Valve, which was a direct replacement.
Again, I can't guarantee this is the part you need on a NA car.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Have one on my 01 C70. yes air passed only one direction. I did not have one on hand and did PCV system replacement without replacing it. Would have preferred to replace it
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Been thanked: 504 times
This is probably correct PN.101 wrote:...I ordered 1275226 - Volvo EVAP Check Valve, which was a direct replacement...
Also, see the thread by sleddriver below:
viewtopic.php?t=54546&start=20
- 1077 Views
Last post by hadleyet
- 983 Views
Last post by T5AUS
- 5091 Views
Last post by beigg
- 2460 Views
Last post by RickHaleParker
- 15702 Views
Last post by lext
