Hey guys new member here, I've had my xc90 for about a year now without much issues. I do all of my own work and just recently replaced my haldex pump, the pump was indeed bad. To my surprise though it didn't fix the issue and now I have many other multiple issues. I let my battery get low and I don't know if this contributed to the issue or no but I have charged it up by the car (it started on its own power). To start my central locking will not work, or my interior lights when I open the doors (work when I push the button) no running lights, rear door windows do not work and my awd.
I tested at the rem for my awd and no power if I apply power I do get my awd back, this made me assume the rem but all of the other circuits that don't work have power to them (also my brake lights work). I have checked all fuses and they seem to be good the only one I found bad was an inline fuse for my trailer lights that are after market, I replaced the fuse but no luck. I also removed the wiring completely and still no luck. I'm confused on where to look with out having a vida/dice. Looking for any hints or places to look? Ground? I think it's coincidence that it happened the same time I replaced my haldex pump.
2006 xc90 electrical gremlins
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
Did you try to disconnect battery? But, put and turn key to second position before connect battery.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
justind710
- Year and Model: 2006 xc90 v8
Yes, I did. I'm trying to get a dice set up to investigate further.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Lets us know once you find out. Thanks. Also be sure battery is fully charged.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 902 Views
Last post by ggleavitt
- 2812 Views
Last post by scandisk
- 11 Replies
- 2229 Views
Last post by mrbrian200
- 680 Views
Last post by mathy221984
- 1099 Views
Last post by oragex
