My 98 XC was left with the key turned to "on" and the seat heaters on. The battery drained. When I charged the battery and tried to start it again, it would not fire. When I checked for spark (with a fully recharged battery), there was none...
Could I have "cooked" my coil or something else by leaving the key in the on position until the battery died?
1998 V70XC - No spark after battery drained
Possible but I doubt it, pull the coil wire from the distributor and clip it to a position near the engine block and see if you are getting spark when you crank.
- dyn blin
- Year and Model: 1997 850 Wgn
- Has thanked: 1 time
- Been thanked: 2 times
If your battery was under load long enough, it may have sulphated. If it is, it may seem to hold a surface charge, but the plates have been covered and allow only a small discharge, so the amperage and voltage won't be enough to start the car.
Try a new battery. You also may be able to jump start, but if the old battery is sulphated, you'll need to replace it.
'97 850 GLT Wagon- Driving to see 300k in the rearview
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Immobiliser kicked in.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I think you are right misha.misha wrote:Immobiliser kicked in.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
On a '98, there's only a starter cut.
And lights would be flashing and the
little horn would be trying to beep.
I'm thinking that if there's enough juice to spin the starter,
there should be enough to light up the plugs. Got a meter?
Time to start walking through the basics...
- 2220 Views
Last post by alschnertz
- 2534 Views
Last post by contented
- 1252 Views
Last post by oragex
- 37 Replies
- 10329 Views
- 53 Replies
- 6818 Views
Last post by jonesg
