Hi,
I'm new here and I have a 98 S70. A couple of days ago the button that pops open the panel that covers the gas cap stopped working. Is there a way to manually open that panel? I'm running low on gas here!
Any help would be appreciated.
S70 How do I manually open the gas cap panel?
1998 Volvo S70 B5254FS 93k miles
Recently Replaced Parts:
Yokohama Avid H4S Tires
Bosch Platinum +4 Plugs
Bosch Plug Wires
Bosch Distributor Cap/Rotor
Bosch Front O2 Sensor
Front Engine Mount
Bosch Plug Wires
Front Engine Mount
- Has thanked: 17 times
- Been thanked: 35 times
There is...it's just between the motor mechanism and the side of the fender and it's not a ring-pull like the 850's...it's more like a lever....reach in there and you should be able to feel it. Just pull whatever you can get your finger around and eventually you'll pull the righ thing...I'm serious.
