Hi Folks,
I just discovered that my radiator is leaking. Typical crusty deposits are forming on the edge of the radiator right at the seem of the plastic body and aluminum fins.
My car is a 99 s70 base model with a manual transmission.
In my casual research it seems that radiators specific to manual/non-turbos are not as common as those for turbo/automatics.
It seems that even though my car is a manual, I think I could use a radiator meant for a car with an automatic but that I would just not use the transmission oil cooler connections on the side of the radiator.
Is this correct? Or am I wrong about this?
Is there any specific advantage to hunting down a radiator made specifically for a non-turbo manual? (better fit, more clearance without cooler connectors, etc)
Thanks
abler man
Correct radiator clarification question
Exactly right. I've got a recent thread showing the inside of the cooler
viewtopic.php?f=1&t=79799&p=429948&hili ... ns#p429948
You just hook up the rad, ignore the AT hookups, and sneer at Matt for having a 5 speed
- Has thanked: 17 times
- Been thanked: 35 times
LOL...well said sir, well said!
- 872 Views
- 1752 Views
Last post by amblerman
- 2786 Views
Last post by TheMrFailz
- 1998 Views
Last post by BEJinFbk
- 7333 Views
Last post by Mikele82
