p80 rear brake pad review. Pagid brand
Has thanked: 1609 times
Been thanked: 4065 times
I did new pads on rears on the 1999 last year , or two?
Stopping power is great but the squeal like " Deliverance" even with new rotors
This is great for two reasons
Pedestrians hear you coming
If you practice a bit, you can play " Dixie" coming to a stop, which amuses me
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
abscate wrote:I did new pads on rears on the 1999 last year , or two?
I have had great success eliminating the noise by installing the "anti squeal shims" from Volvo and using a liberal amount of Permatex brake paste on the back of the pads:
https://www.amazon.com/gp/product/B0018 ... UTF8&psc=1
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 2199 times
Been thanked: 1851 times
Many years ago, in Europe, we used to have bumper stickers that read, IF IT SQUEELS, IT'S A VOLVO! This issue comes up many times and the solution is to fit the shims, or learn to amuse yourself with them as you do!
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I've always had copper spray that I'd hit the backs with and then lube the heck out of the slider pins. Not sure if this is any different with a Volvo but it works fine on the MC and previously on the Dodge, VW and Ford.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I think I should have gone heavier with the brake lube. I have Centric brakes from the wonderful (not) Rockauto. "C-tek" rotors and ceramic pads. They don't stop that great and they make a whirring/squealing noise while I drive, but it's intermittent. They're much better than my old original 174k-mile rotors, but they aren't as good as I would like. At least they stop quietly. It could be that I somehow bled the brakes wrong, but I highly doubt that. I got all the air and a lot of nasty old fluid out of there, the master cylinder looks very clean now.
Oh well, I'll live with these until I upgrade to 302s with some Akebonos.
wizechatmgr
Unknown to most but cars that have ABS can get air stuck in the ABS control module/manifold occasionally and it isn't fun to get out. Usually you require a dealer level scan tool to open up all of the valves to bleed it correctly using a vacuum bleeder. Whatever you do -- don't let the reservoir run dry.
bmdubya1198
wizechatmgr wrote:Unknown to most but cars that have ABS can get air stuck in the ABS control module/manifold occasionally and it isn't fun to get out. Usually you require a dealer level scan tool to open up all of the valves to bleed it correctly using a vacuum bleeder. Whatever you do -- don't let the reservoir run dry.
Oh great... that sounds like loads of fun. Yeah, I never let it run dry. That's just a way to introduce more air into the system... rather counterproductive method of bleeding your brakes.
