The power window on the passenger side (front right door) doesn't work as expected. When I want to rise the window up, I need to pull the window switch and keep it pulled. If I let go of the switch, the window motor stops. This only happens with this window - all three other windows continues all the way up. Also, the "window down" works as it's supposed to (press the window button down and hold it down for a short time, let go and the window continues down as expected).
This is a problem both when operating from the driver door panel and from the passenger door panel - exactly the same result - need to keep the switch pulled until the window is completely up.
I can't find a wiring diagram for the power window system (I have tried to google) - so I have no idea how this is all connected.
OK - what is wrong? Wiring diagram anybody?
Power window has a problem
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
looks like the automatic function doesn't work. happened all of a sudden?
maybe try disconnecting the car battery red wire for a few hours - have the ignition key in position II while working at the battery. when the computer resets you will see no lights on the climate control fan speed button
Geir Nordvik
- Year and Model: 2003 V70
I'm not sure when it happened. I do not open this window very often, so it may have been like this for a while. Does anybody have a wiring diagram for the power windows? Since this is a problem for both switches (in both doors), the problem is likely in the module that controls the motor. I will try to pull the fuse for the passenger side door and see if that solves the problem.
