1998 S70 t5
So my car wouldn't start this morning and I ended up taking my truck to work. When I got home tried to diagnose the problem and the first thing I noticed was an actuator buzzing which appears to be part of the vacuum system. It is positioned directly in front the throttle cable wheel. The first picture shows a overview and the second picture is a closer view of it. My description would be that it is a silver tube actuator with a plug coming out the back end of it and vacuum tubes coming in and out of the front of it. Any way as any good mechanic would do (okay to be honest I am not a good mechanic) I tapped the end of it with a screwdriver to see if it was stuck. Then I unplugged it and plugged it back in. Afterwards the car fired right up. I'm thinking that something was stuck and tapping it unstuck it. I think this is the problem and the part is bad, the problem is that I don't really know what the part is called for me to try order one. Can someone identify the part of which I'm speaking?
No start - buzzing sound in vacuum system
- misha
- Has thanked: 155 times
- Been thanked: 432 times
That's IAC valve and it's supposed to buzzz when key is in pos.II.
Don't need to replace it as long as it's working/buzzzing.
You can clean it with carb cleaner,instructions are in repair data base.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Yes...sort of.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- AKJeeper
- Year and Model: 1996 850 Turbo Wagon
- Has thanked: 7 times
The valve controls idle speed. If the valve got stuck, the car would have started if you put your foot on the throttle a little bit (like 1/8 or 1/4 throttle opening) while cranking. It probably could use a cleaning.
- 3992 Views
Last post by Dave0304XC
- 1547 Views
Last post by azureblue
- 4347 Views
Last post by sleddriver
- 478 Views
Last post by Reilly2004
- 4026 Views
Last post by SimLyons
