ps pump went south Topic is solved
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
On our 95 854 the power steering pump went south today, leaking all over the place. My wife drove home for about a mile with little fluid in the reservoir and a groaning pump. What are the chances the rack and pinion survived? After refilling the reservoir the pump still groans and leaks fluid.
1996 855 R,
2010 V70 D5,
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Probably. Change the pump and find out.
85 GLH, 367 whp
00 Insight, 72 mpg
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
More likely they survived -- if they weren't an additional source of leaks.
Has thanked: 1609 times
Been thanked: 4063 times
The rack will live without pressure just fine. It doesnt blow up without oil pressure like a transmission.
Clemens
Post by Clemens »
Thank you
1996 855 R,
2010 V70 D5,
Clemens
Post by Clemens »
So, finally, I got all the parts (used pump, new pressure line o ring, 4 Quarts of ATF) and watchd Robert´s Video in order to tackle the job. Looks like the pump was not the culprit but the pressure line being lose. When I tried to unbolt the pressue line i felt that it was extremely easy to turn with the wrench. After close inspection i saw the old o-ring was pretty ugly. So i gave it a try, replace the o-ring and after some bleeding the old pump runs just fine.
I have no clue why that line came loose after 300.000 km and 21 years, but it was quite an easy fix. Let´s see how the alternator and AC pump hold up after being flooded with ATF (and rinsed with brake cleaner and water).
1996 855 R,
2010 V70 D5,
Its good for them. It helps the electrons flow faster when they are coated in ATF, then the brake fluid helps them stop.
You will be fine.
dyn blin
Year and Model: 1997 850 Wgn
Has thanked: 1 time
Been thanked: 2 times
Post by dyn blin »
Thanks abscate,I had almost forgotten about the Henway effect from auto shop class.
'97 850 GLT Wagon- Driving to see 300k in the rearview
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
I have had that issue too once on a car that I hadn't messed with and once on one I changed the pump on- I replaced the oring with one made to resist acids and stuff- only one I could find and it has been fine-
dyn blin wrote: 05 Apr 2017, 09:03 Thanks abscate,I had almost forgotten about the Henway effect from auto shop class.
:D :D :D :D
