96 R: idle not super smooth
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
As it is getting warmer again I am trying to sort out various things on my rides. On my 96 R I noticed that idle isn't perfect. Within the last year I put new plugs, wires, cap and rotoe on ot (all oem) did the PCV twice, new airfilter.
I have an old O2 sensor, no codes, good even compression, a slightly leaky turbo, vacum lines that look good but haven't been replaced (will do soon) and a fuel filter of unknown age. Also, a few lifters are ticking occasionally.
What to do next besides shut up and drive?
1996 855 R,
2010 V70 D5,
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Have you cleaned the throttle body and or Mass air flow sensor?
Clemens
Post by Clemens »
Throttle body? Yes, includong new seal. MAF: no! Die to lack of proper cleaner on my side of the pond.
1996 855 R,
2010 V70 D5,
ZionXIX
Post by ZionXIX »
I have used brake cleaner on a non volvo vehicle while being careful not to touch the resistor filament things and then letting it air dry in the sun for a while. Use at your own risk.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
I would check for fracked vacuum lines. All three of the 98 to 2000 Vs we have had cracked lines causing poor idle. Having seen brake cleaner melt plastic I would be wary of using it on the MAF sensor. Use the CRC MAF cleaner.
