Best place to pass a wire through the firewall 98 non turbo
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
I'm trying to run an accessory wire directly to positive battery terminal. It will have an online fuse and proper grounding. Where is the best place to pass this through the firewall? I thought about up through the fresh air filter and along the firewall to the battery or maybe where the steering column pokes through? Thanks
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If it's less than 30 amps, there's no need.
You can pick it up at the factory accessory
connector under the dash. Look for an unused
yellow connector attached to the side of the
steering column bracket.
If you do have a larger load, like a big amp,
look for the existing grommet low on the
driver's side with several unused nipples.
Volvo saw you coming and has your back!
1998 P80 AccConn Locations.pdf- (514.81 KiB) Downloaded 241 times
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Bad link.
- rspi
Contact rspi..
- BEJinFbk
Shouldn't be - It's a PDF uploaded to the MVS server.
Looks like Matt's been upgrading, though. Try Again!
- rspi
Contact rspi..
I posted a bad link and wanted to delete the post but couldn't. So I erased the post and put "bad link". YouTube has made some kind of change and it is not giving me links like it has over the past 4 years.
- 8043 Views
Last post by MrAl
- 47 Replies
- 4981 Views
Last post by MrAl
- 23 Replies
- 8310 Views
Last post by BEJinFbk
- 490 Views
Last post by RickHaleParker
- 722 Views
Last post by bob-in-va
