Drivers side door
tom4342
Year and Model: 1998 v70 awd
Post by tom4342 »
My 98 v70 drivers side door use to make a loud popping noise when opening and closing now i noticed its quite but wont stay open any longer tends to close on my leg is there a spring that maybe broke?I bet there is no chance of find a replacement huh?
Tom Hood
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
The broken part is called a "door check" or "door check strap" and it is cheap and easy to fix but you will need to check if it is simply the strap is broken (super common, easy to fix) or the weld has broken (common problem, PITA to fix).
Richard_TD
Year and Model: 855 2.5 20V 1996
Has thanked: 6 times
Been thanked: 5 times
Post by Richard_TD »
This is how I dealt with the broken welds on mine. Taking the door off is easy, except that it's quite heavy. The tap and die set and pop rivets are red herrings, I actually drilled holes through and used nyloc nuts on the inside. That was 3 years and 30000 miles ago and it's still fine.
1996 855 GLT 2.5 20V
Has thanked: 2210 times
Been thanked: 1852 times
Only thing I would have done (and maybe you did) would have been to drill a small hole at the end of the cracks to reduce the likelihood the cracks will spread further. Simple but effective fix!
Neil
Richard_TD
I didn't do that, but now you've mentioned it I will if I ever do the job again.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
