Which is the timing mark
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
Not sure which mark is the timing mark. How should be set both intake and exhaust have same marks.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
For which Volvo? This blue thing is a hub and you have to adjust that too. I'll let others chime in.
stephansvolvo
2005 v70. The head has been replaced
Stephan
98 S70 GLT
73 IH Scout ii
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The hash mark is the one that was put on the gear as the engine was set up and cam timing was set. Were the gears removed from the cams? If they were then the full set up procedure will have to be done. Tell us more.
The cam pictures is one tooth advanced. The other mark is usually the top cover's notches but the boss on the CVVT solenoid that is aligned with the tooth to the left with the 0 in its base is aligned with that boss as happens to be depicted in the photo.
stephansvolvo
So this post it's for friend. The water pump seized up and causing valves on most every cylinder intake and exhaust. They got a new head and the timing need set. And I'm not Milyer with this particular year so I thought I'd ask you guys for him.
Stephan
98 S70 GLT
73 IH Scout ii
Has thanked: 1609 times
Been thanked: 4065 times
This one is more complicated than just setting marks. Friend needs to slow down, put tools down and research the CVVT cam setting in various threads before he cooks his engine again.
The VVT means the cam moves with respect to the gear, so the procedure for getting it right is important.
