C70 t5 3" downpipes
belskee
Year and Model: C70 t5 00
Post by belskee »
Hi everyone I'm looking to upgrade the exhaust on a c70 t5 2000, I'm assuming I can fit the s60r manifold as it won't change the position of the turbo is this correct?
I'm also looking to get a 3" downpipe but I am having trouble finding for this model, would the downpipe from the s60 and v70 fit the c70?
belskee
Post by belskee »
So with a little more research I'm now thinking the downpipe fitment for the s60 won't fit the c70 although the manifold will, would be great if anyone can confirm this.
If the s60r manifold will fit a c70 am I correct in thinking the r turbo will fit as well?
jantt
Year and Model: C70 2000
Been thanked: 2 times
Post by jantt »
I have a C70 LPT 2000 and mounted this : https://www.bsr-tuning.dk/produkt/3-dow ... 9-2005-2wd
It`s in danish so you may have to google translate :)
Also got BSR software, 2,5" exhurst with only one muffler, race intercooler, reversed steelpipes, open airfilter, porsche tcv
Got it from 193 hp to 280 hp
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
The S60R manifold will fit, also it is the same manifold on all 04 - 09(?) 2.5l engines. No the S60 downpipe will probably not fit, designed for a different body style. Use the downpipes listed for 99-2000 S70s and V70s. (or 98-99 depending on when UK used Electronic throttles, and then when they changed to the V-70 series II and S60.) There are kits to adapt the K24 turbo to the P80 cars, but it won't just bolt-in with no supporting changes.
Also, when you go to the later exhaust manifold, you will need to bring over the heat shield as well, it was changed.
Current Volvos:
FLXC90
Post by FLXC90 »
the supporting changes will be the oil and water plumbing for the turbo, and the charge pipe to the intercooler. I don't know about the fresh air pipe for the turbo.
Forum member BMDubya1198 may have more info, I think he's running a K24 on an N motor.
Current Volvos:
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Looks like the same downpipe I have on my S80 2.4T (2001). I did a double check by the webshop (they checked with BSR) if it would fit the S80, as the S80 was not on the compatibility list. Build quality is excellent, still love it every day!
ImageBSR 3" Downpipe with Sports Catalyst by Andy Ramdin, on Flickr
ImageVolvo S80 2.4T 3" BSR Downpipe by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
