Automatic Transmission Fluid '97 V70 na
Caspar
Year and Model: 97 V70 2.5 10V
Post by Caspar »
Dear Forum,
the transmission fluid in my '97 V70 na is somewhat over max. As far as I can tell from the indicator stick, readings differ depending on orientation, but it always indicates to much.
It's been like this since 25k km now, since I got the car. I wonder if I should do something about it, planning to change fluid anyways at some point, though.
Transmission works normal, can feel shifts from 1th to 2nd, otherwise smooth.
Opinions?
Thanks!
Caspar
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Hi Caspar, the amount of fluid that drains out of these transmissions is pretty consistent. And considering how old our cars are, I think you certainly couldn't cause any damage by draining it and then refilling it with the correct amount. In fact, your transmission would probably like that. I'd be inclined to do a drain and fill.
Retired:
2015 Volvo S60, T5, 85K
Has thanked: 1609 times
Been thanked: 4064 times
You need to follow the procedure to check the level precisely, Caspar. Check your owner manual for the conditions of the check, it is completely different than checking the engine oil.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Are you checking with the engine running or off?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Caspar
Post by Caspar »
Off - just saw Robert's video how to do it properly.
Will check again.
Caspar
Post by Caspar »
Ok, using Robert's instructions from the video (checked with motor running, after 30min drive through town) I read a level close to minimum.
Will do a drain and flush next and refill drained amount.
