Cruise control doesn't function and the radio controls on the steering wheel don't function. Sometimes. But sometimes they do. And the functional state of each is determined at ignition. When starting the car, cruise control may or may not work. And it stays that way until the engine is turned off and restarted, at which point it again may or may not work. Same for the radio controls. Controls on the radio itself always work fine. And the cruise control and radio steering wheel controls aren't always affected at the same time. I haven't noticed any other patterns of failure, but they may be there. Seems like these symptoms may point to a specific dysfunctional part or parts. I have not found this behavior described online, but it may there also.
Any suggestions would be great. Intermittent problems are difficult to troubleshoot.
Thanks,
Dave
2004 xc70 with intermittent cruise control and radio issues on ignition
- Been thanked: 4069 times
Maybe catch me in Boston sometime and read DIM codes? I'll bet some are set
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
Having lots of fun with my Autel. Had many codes = set 1 below. Cleared them. Drove about ten minutes up tp 50 mph. Cruise control and radio buttons did not work. Then many fewer codes = set 2 below.
I know completing a "drive cycle" (or maybe two) is important to ensure that all ODB-II tests are valid. Is the same true for non-ODBC DTC like these? I know it is for at least some because I have watched them pop up with driving. Will most of the codes in set 1 likely recur with more driving? I expect the two intermittent codes will become permanent.
Set 1:
ECM-928C
CEM-821C
CEM-6A03
REM-8F10 signal too high permanent
SWM-000A faulty signal permanent
SWM-0028
SWM-002A
SWM-002B
SWM-0009 signal too high permanent
SWM-0008
SWM-0029
DDM-002B
DDM-0024
PDM-002B
Set2:
ECM-928C faulty signal
SWM-000A faulty signal intermittent
SWM-0009 signal too high intermittent
Set 1:
ECM-928C
CEM-821C
CEM-6A03
SWM-0028
SWM-002A
SWM-002B
SWM-0008
SWM-0029
DDM-002B
DDM-0024
PDM-002B
Set2:
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
- 1716 Views
Last post by kimthepilot
- 2436 Views
Last post by dux02v70
- 17 Replies
- 6479 Views
Last post by ignatz
- 190 Views
Last post by br0dy519
- 11 Replies
- 3422 Views
Last post by firstv70volvo
