Got this Volvo last year and took it for new transmission. Before then, I had replaced the radiator (DIY).
Now, brought it out to drive. While replacing the oil and filter, I found this hose. It is 'plasticy" not rubbery.
I was tucking it in when I realized it did not terminate anywhere. What would it be for?
Looks like it would terminate around the bottom of radiator. Just a guess!
Looks like the fuel line should be the one above this one in question, which is also a steel hose.
Thanks.
Found This Loose Hose Underneath. What Would It Be For?
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- Been thanked: 4064 times
ITs probably the EVAP hose to the purge canister. Look under your hood for a hose diagram and see if you can place it on there.
Oka
Just reporting back on my finding. Yep, you are right. Visited the Volvo dealer in town and was told it's the Evaporation System hose line, supposed to be connected underneath the manifold. Googling to find where the connection would be at the manifold - will also look for the diagram you mentioned.abscate wrote: 03 Apr 2017, 10:50 ITs probably the EVAP hose to the purge canister. Look under your hood for a hose diagram and see if you can place it on there.
Thanks you all.
If it doesn't look right or you can't figure the diagram out, post a pic here in this thread.
Volvo sometimes outs the wrong hose diagram under the hood just to enable Internet fora like MVS
- 641 Views
Last post by hankeester
- 13 Replies
- 4457 Views
Last post by kahl
- 78 Replies
- 12177 Views
Last post by PeteB
- 1040 Views
Last post by ndphotonl
- 40 Replies
- 11606 Views
Last post by cn90
