My V70 1999 2.4 Sounds like a Tractor - why?
bluebossa
Year and Model: 1999 V70 + XC90 2008
Post by bluebossa »
Anyone heard similar to this before and can point me in the right direction?
1999 V70 2.4 SE - UK
2008 XC90 V8 4.4 Executive - UAE
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Could it be a very loud serpentine pulley? Such as the a/c one. Does the sound go away without the belt (you can run the car at idle 1-2 min without the belt on). Another way to locate a noise is to use a 2-3ft tube (I use a shower hose) and carefully approach one end to the engine while listening to the other end at the ear.
Darkfleet
Year and Model: V70 1999
Been thanked: 3 times
Post by Darkfleet »
Sounds like maybe your exhaust header is cracked?
When cold pull the heat shield (1 bolt) and start it and feel for leaking air at the side of the head closest to the firewall.
bluebossa
Post by bluebossa »
Thanks but goes away after revving to 2k?
Has thanked: 2196 times
Been thanked: 1850 times
I would suggest one of 2 things:
1) Cracked exhaust manifold or failed gasket or broken flex-pipe in the downpipe. Rev'ing may just cover this issue.
2) More concerning may be lack of oil getting to the head. Raising engine speed may just increase oil flow to starved top end. Try running a thicker oil to see if it helps. The issue may be the oil pan 'O' rings have failed not allowing oil pressure to the head until higher revs.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Sounds like a bad crankshaft pulley balancer. I heard the same noise on 2 family Buick 3800 engines and a friend's Ford and in all 3 cars the balancer had broken lose of the pulley the serpentine belt runs on. All 3 cars only made noise when idling and noise went away when rpm was increased. All 3 cars were normal after replacement and all three balancers had the rubber bushing between the balance weight and pulley was gone also with the engine off you could hand move the serpentine belt a few inches back and forth by hand between the stop pegs. Worth checking, June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
bluebossa
Post by bluebossa »
June wrote: 06 Apr 2017, 16:32 Sounds like a bad crankshaft pulley balancer. I heard the same noise on 2 family Buick 3800 engines and a friend's Ford and in all 3 cars the balancer had broken lose of the pulley the serpentine belt runs on. All 3 cars only made noise when idling and noise went away when rpm was increased. All 3 cars were normal after replacement and all three balancers had the rubber bushing between the balance weight and pulley was gone also with the engine off you could hand move the serpentine belt a few inches back and forth by hand between the stop pegs. Worth checking, June
Thanks June - sounds promising... will check and report back
