1996 850 manual transmission issues
mckinney
Year and Model: 1996 850
Post by mckinney »
Hi - I have a 96 US spec 850 wagon with tracs and the 5 speed manual gearbox. The gearbox has developed a ticking sound at highway speeds in 4th and 5th gears. While driving it sounds as though the ticking noise is coming from the tires. However, with the car on a lift, the sound is clearly coming from the gearbox. Does anyone have any thoughts on what might be causing this and how long before it gets significantly worse? (it's not affecting driveability at the moment) The car is with me in the Middle East until June '18 while I'm on assignment. There are Volvo dealers here, but none of them have parts for earlier cars. To fix this, I'll need to order the parts from the US and have the dealer install them. No idea what parts are needed.
many thanks for any responses.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 36 times
Post by theWIFES_S70 »
Have you replaced your transmission fluid? And transmission fluid leaks from the axle seals?
Retired:
2015 Volvo S60, T5, 85K
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
There is no serviceable parts inside the transmission you can get.
I'd suggest you start looking for used transmission.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 1507 times
Been thanked: 3825 times
McKinney..I would be tempted to just drive it and fix it back here where parts/used transmissions are readily available and cheap. If its a higher frequency tick it probably isn't serious yet
mckinney
Post by mckinney »
Thanks guys, I appreciate the responses. Wifes_S70 - I don't know whether the fluid has been changed. Will take it to the dealer and get that done and also leaks checked, but pretty sure there are no leaks.
850 LPT
Year and Model: 96' 850
Has thanked: 332 times
Been thanked: 243 times
Post by 850 LPT »
Are you really sure this noise is coming from the transmission? I would maybe try to pinpoint again and see if the axles could be the culprit here. In my mind, if something in the tranny would fail it would make more of a whining/ grinding kind of noise.
Just a thought.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
