07 XC90 3.2 Oil trap loud hissing noise
vmaxmike
- Year and Model: 2007 XC90 3.2 190k
Has anyone with this model engine or newer have the loud whistling / hissing noise happen that comes from under the hood resulting presumably from a clogged oil trap box? Is it possible to clean or service it? Thanks
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
I do not have that engine but I would assume PCV is a routine service item
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
vmaxmike
Yes, I replaced the oil trap box with built in pvc diaphragm on top of engine and issue solved. Took 10 minutes however $180 for the new part. Naturally Volvo doesn't provide a repair kit which would allow for a cheap and easy replacement of just the rubber diaphragm (part that eventually tears and fails) and cap which pops right off with a little force. Would be nice if some after market company made these like Dorman does for VW/BMW which go for around $20!
raquette
- Year and Model: 2010 xc90, 2007 xc70
- Been thanked: 4 times
on this topic, is it possible to replace the diaphragm with a part from a used cover, assuming the part can be removed from a donor vehicle and reattached?
also I've seen the pvc oil trap covers on ebay or parts sites for between $60 to $175. this is a plastic cover.
Are the cheaper covers acceptable?
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Internet search "B6324S pcv diaphragm replacement", been seeing just the diaphragm offered over the last year. Seems like it could a viable alternative to replacing the cover outright.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
All,
It may be cheaper to buy the part from Land Rover
Note: the 2008 - 2012 Land Rover LR2 uses the Volvo 3.2
The Land Rover part number is LR023777 it is the same vendor, same part as the Volvo Part it just comes in a Land Rover box
Note: this is for the 3.2 and not the 3.0T
A link that shows what needs to be replaced
http://www.freel2.com/forum/topic32107.html
If you are really ambitious you can try to replace just the diaphragm
Based on what I've read you will need a heat gun
https://www.ebay.com/itm/172267660060?ul_noapp=true
If you just replace the diaphram please let us know how you did it
Thanks
Paul
Thanks
Paul
raquette
installed the aftermarket cover and was i surprised when the bolt holes were slightly off - the repo part is not made exactly as it should be. just what i was concerned about by this $42 part.
so all but 4 bolts lined up at one end end with the threads. there I popped out the aluminum inserts, cut them in half with the cut off wheel, and reinstalled to get some stretch in the plastic opening that allowed the 4 bolts to line up.
cheap was not the way to go, but the hiss is gone!
JohninMaine
- Year and Model: 2010 XC70
Hi, raquette and pgill:
I am attempting to replace the diaphragm. Thank you both for your information. You mentioned the use of a heat gun. Is that needed in order to soften the cap so that it can be removed? Sadly I tried to pry it a bit too hard and some of the plastic around the edge broke off. Getting the cap to pop off is not so easy. Any suggestions would be much appreciated.
Also, raquette, I just ordered an aftermarket piece for $40 from a Chinese distributor. I'm now worried that I will get the part that has the misaligned holes, given the low price. Do you recall where you purchased yours?
Thank you! John
Thank you! John
JohninMaine
Here is an image of the item that I ordered. I'm worried that the holes won't align.
https://www.aliexpress.com/i/32978391356.html
- 2059 Views
Last post by Botbasher
- 1260 Views
Last post by dairyqueen814
- 11 Replies
- 2171 Views
Last post by tryingbe
- 2856 Views
- 12 Replies
- 3016 Views
Last post by jimmy57
