2004 XC70 Immobilizer See Manual Topic is solved
goldmandan
Year and Model: 1999 S 70, 2000 V70
Post by goldmandan »
Ok, the XC70 we have runs great but just yesterday the "Immobilizer, see manual" message came up on the dash as I tried to start and it wouldn't. I have a complex scanner and put it in..... nothing showed up (no codes). I let the car sit a few hours, still no start. I tried the unlock/lock 5-6 times with the remote....still no start..... is it the batteries in the remote that are bad? I get the lights to come on, radio etc etc... battery is still strong just no start.... what to do?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Not a common issue, but there were a few antenna ring failures. Easy to replace with a used unit. Or maybe the chip inside the key got damaged.
goldmandan
Hello
If I get a used antenna ring, will it need to be programmed? I was thinking it may be the battery in the keyfob? But it locks and unlocks the doors with no problem. The other funny thing is that when I put on my Autel Maxisys Pro and read codes, there were none. Only a few codes pertaining to check engine light which I knew about.
goldmandan
it was the ignition trigger wire at the starter was corroded now works fine again
Has thanked: 1609 times
Been thanked: 4065 times
Interesting! That fault triggered an immob message?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Just a note: The key has to be in fully unfolded position in order for the engine to start and run. If your key has the failure where key blade doesn't snap out and lock this can lead to you turning the key on and cranking it over with the key folded to some degree and the chip can't be read by the antenna ring.
Xc70Ken
Year and Model: 2004 XC-70
Post by Xc70Ken »
Had misplaced main key
Locksmith tried clone service key...couldn't....then service key would not crank engine
Found main key, cranks, but no start.
Pressurized fuel in fuel rail....
Xc70Ken
Post by Xc70Ken »
No codes..
Clear code command sent anyhow...still cranks no run main key. No crank service key.
Xc70Ken
Post by Xc70Ken »
No codes..
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
crank no run, thats not the immobilizer .
are the injectors pulsing ?
