1998 volvo v70xc transmission fluid
Switchemlee
Year and Model: 1998 v70 xc awd
Post by Switchemlee »
When i check my fluid when cars off i can see it in the dipstick. When i check it after running for 30 minutes and while its idling there is no fluid on dipstick?
Switchemlee
It is really cunfusing me how i cant see itbwhen the car idles and us warm but as soon i turn it off and check the fluid a minute later i can see it on the stick
Has thanked: 1853 times
Been thanked: 1714 times
I can't recall with that transmission if you check it when it is hot, or when it is hot and running. Do you have the owners manual as it will state the correct method? I will have a 98 handbook somewhere, but will have to take a rummage around to find one.
Switchemlee
It says the check after 30 minutes of driving while the car is idling.
Switchemlee
I go thru the gears park to drive and wait 3 minutes thenccheck and the fluid doesnt show up on the dipstick. But when i turn it off it shows up on the stick.
Switchemlee
Yes it says to check while hot and running.
Switchemlee
So i houls go off of the hot and running level? Not the cold and not running level? Whike its hot and running idle there no fluid on the stick. While its cold and not idling its got fluid on the stick
Switchemlee
So i should*
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Best way to check, in my opinion, is to get it all warmed up like you said after some driving, park it on a flat surface with the engine running. Cycle through all the gears for a few seconds at a time, returning to Park at the end. With the engine still running, go out and check the level using the "Hot" marks. If there's no fluid on the stick after doing this, you need to top up.
Cold readings with the engine off is the wrong way.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Switchemlee
Ok thank you:)
