Just started to get a message "Low Oil Level" (Note: check engine triangle has also now lit up). I checked the oil and the level is slightly above the mid-range between full and low as indicated by the "xxxxxx" area on the dip stick. I will top it off and see if that resolves the issue but it would seem that either way the sensor is coming on prematurely. Has anyone had this issue and also if you needed to change the oil level sensor what is that procedure? Car runs fine and has about 135,000 miles on it.
Thanks
2006 XC90 V8 - Low Oil Level Warning - Check Engine
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Tested it at the 3/4 filled line... and the light came back on. I will test it at full mark and report back. Anyone have tutorial / instructions for XC90 V8 for replacing that oil level sensor if needed?
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
topped off light stays off. guess it is telling me to keep it full.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 48706 Views
Last post by ggleavitt
- 2437 Views
- 5525 Views
Last post by Cees Klumper
- 1505 Views
Last post by mortaay8444
- 427 Views
Last post by Pennybags
