Used Wrong PAG Oil......
Annihilator
- Year and Model: 1993 850 GLT
Hi all, I mistakingly added 3 ounces of PAG 150 (correct for my truck) oil in my '97 which I believe calls for PAG 46. I added oil this time as I have an A/C leak and have to charge it at least once a year. A shop can evacuate the system but I believe there is still majority of oil left in the system. I hear there's a drain bolt on back of compressor? Ideas? Thanks!
1995 850 GLT - SOLD
1993 850 5 - Speed - SOLD
1997 T-5 203k
2005 S80 AWD 112k 2.5
1997 T-5 203k
- Been thanked: 504 times
I'd not worry too much.
Different PAG oils just have different viscosity.
If you a little search, then PAG 46 (thin), PAG 100 (medium), or PAG 150 (thick) is almost like the oil analogy of let's say 5W30, 10W30, 10W40 and all that jazz.
PS: Most compressors do not have a drain plug simply b/c there is no need for that. You can suction some out using a small tube and syringe etc.
But a bit of PAG 150 in that system is fine.
- 1115 Views
Last post by combatkarl
- 1985 Views
Last post by jimmy57
- 4101 Views
Last post by APAudVid
- 934 Views
Last post by LOB
- 1516 Views
Last post by Rvolvos
