Thumping from front of vehicle
Flip07
Year and Model: XC90 2006
Post by Flip07 »
As I am driving straight down the road, the car rides fine. As soon as I am decelerating and/or turning right, I get a thumping sound from what appears to be in the right tire well area. Significant enough to send the vibrations through the car. When I accelerate and/or turn left it goes away. Not sure if related but I feel the vibrations through the steering wheel, but it does not seem to be from the steering column. I had the car alignment adjusted, and it seemed to make it smoother, but the thumping came back over time possibly masking the issue. The brakes and rotors have been replaced. Not sure if related but the steering wheel is not centered when driving straight, it is angle at about 30 deg left side down. I have a video I'll post on youtube shortly to see if viewing helps the troubleshooting. Please help. the language barrier with the mechanics while I am deployed overseas makes trouble shooting harder, and I really need to go to the shop and tell them exactly what I need done.
Thanks,
Flip
Flip07
Post by Flip07 »
Here is the video of the thumping sound. You can see the steering wheel is not level when driving straight, it's at the 2 and 8 o'clock position but I don't think that is related. As I go into the right hand turn the sound begins.
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
I would consider alignment... for the steering wheel not being centered. Alignment is usually under $100. When on lift they too may notice something else going on.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
Flip07
Post by Flip07 »
I had the car aligned, and the thumping reduced a lot but did not go away. However, it was only about a week before the sounds of the thumping completely returned to the point of being annoying. Not to mention, bad for the car to have something pounding like that. After doing some reading, I don't think the steering wheel adjustment would have any connection to the problem. I thought the Tie Rods may have a slight amount of play at the mounting points, but that is my only guess.
ALF1
Year and Model: XC90 2003 2.5
Been thanked: 5 times
Post by ALF1 »
Highly suggestive of failure in a CV axle joint. Noise appears under strain of acceleration straight or turning.
