98 V70 front brake pad grease
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Post by 98v70dad »
Should I use Sil-Glyde or the tiny tiny moly pack that comes with akebono ceramic pads? Or does it really matter?
I'd rather use sil-glyde because I have plenty of it. Last time I put akebono pads on a car the grease took way too much effort to portion out and the end result really wasn't adequately covered in my opinion. For such an expensive pad I think they should be more generous with the moly grease supplied.
The akebono info says using anything other than what they supply voids the warranty but I say so what? I've never had to return a brake pad and my friends who have tried tell me that there's always a reason that they aren't covered.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I have installed a couple sets of Akebono ceramic pads on the front of our '97 855 GLT and I used ATE Plastilube in the 75ml tube available from FCP and others. It works great. No squeaks or squeals for the past 8 years.
98v70dad
Has thanked: 1 time
Post by 98v70dad »
jreed wrote: 22 Apr 2017, 05:58 I have installed a couple sets of Akebono ceramic pads on the front of our '97 855 GLT and I used ATE Plastilube in the 75ml tube available from FCP and others. It works great. No squeaks or squeals for the past 8 years.
Thanks. I'll be installing them in a few hours and sil-glyde is what I have. Its a silicon based brake grease for brakes. I have no concern about using it. I just wonder why akebono supplies moly based grease and indicates that you MUST use it for warranty coverage.
Has thanked: 2197 times
Been thanked: 1850 times
I use anti-seize copper grease. It also works well and does not tend to wash off.
98v70dad
Has thanked: 1 time
Post by 98v70dad »
Thanks folks. Pads went on the car at 9:30 this morning using the sil-glyde. I expect that it will be fine.
