Metallic "Clunk" when rolling from a stop (99 S70 T5M) Topic is solved
1999 S70 T5 manual. Just started today. When I set off in 1st gear after turning the car on, there is a metallic sounding "clunk" from the front of the car. It happens around 2000 RPM, and only the first time setting off after the car is turned on. If I come to a full stop and accelerate again, it doesn't happen. There is stuff going on with the clutch/flywheel as of a few weeks ago (I think the dual mass flywheel has play in the bearing), but the clunk noise just started today. Any ideas what it could be?
99 S70 T5M - Turbobrick
00 Jeep XJ Sport - Mountainbrick
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Does it happen right at 12 MPH? Because that would be the ABS selt-test. It only does it once after the car is started.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
Wait, for real? I just fixed the abs/stc module. Yes, it happens right around 12 I think... I'll have to test it.ecbsykes wrote: 22 Apr 2017, 18:50 Does it happen right at 12 MPH? Because that would be the ABS selt-test. It only does it once after the car is started.
FlyingVolvo
Haha, yup! If your ABS was broken that's probably why the sound seems new to you. It's almost exactly like you described.. sort of a metallic crunching noise that lasts half a second. Sometimes you can feel a little vibration as it does it. Perfectly normal! Sounds like to me that you fixed your ABS.
2023 V60 T8 PE
2023 V60 T8 PE
It's a dddrrrrrtttt sound
- 1481 Views
Last post by erikv11
- 2782 Views
- 427 Views
Last post by Pennybags
- 2758 Views
Last post by MadeInJapan
- 1877 Views
Last post by Georgeandkira
